flex plate & torque converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2010, 08:41 PM
We are installing a small block 350 and 700R transmission.
The engine builder specified a balanced 350 flex plate. The transmission builder furnished a new converter. The flex plate bolt pattern does not match the converter. Any advice will be greatly appreciated.
Old 01-12-2010, 12:46 AM
SSedan64's Avatar
SBC 350 with the 1 piece rear Main seal Cranks use a Flexplate with a weight added onto it.
SBC 350 with 2 piece rear Main seal Cranks use a Flexplate without the weight.
They come in 168tooth (14") or 153 tooth (12-3/4"). With 10-1/2", 10-3/4" & 11-1/2" Converter bolt patterns. Most aftermarket Flexplates come with 2 or dual Converter bolt patterns.
Which style/size do you need?
168th uses staggered starter bolt mount pattern, 153th uses straight across starter bolt pattern.
Old 01-12-2010, 06:25 PM
gt43
Thank you for the information. We have the one piece rear seal. Will have to check on the other items.
TORQUE INFO FOR 350 TH tranny FLEX PLATE 40forddgc Transmission - Rearend 4 12-02-2009 04:09 PM
Frustrating Powerglide Leak or Torque Converter Leak? 67Elcamino Transmission - Rearend 2 08-26-2009 10:16 AM
Torque Converter Question leejoy Transmission - Rearend 5 10-02-2006 11:57 AM
bop th400 torque converter? meev182 Transmission - Rearend 2 04-24-2006 10:25 AM
torque specs for a flex plate on a chevy 350 to auto tranny badk5 Engine 1 07-01-2005 06:56 AM
