Flex plate/Torque converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-15-2011, 12:14 PM
dilligaf's Avatar
I purchased a new torque converter and a flex plate from a reputable manufacturer. When checking the alignment of the holes, I found that the converter would not fit the flex plate. I returned it to the mfg. and they checked it out. Seemed that the studs on the converter were not welded on in the proper locations. After checking the rest of them in stock they found that they were all wrong. They are reworking it and will deliver it today. My suggestion; Check them out before putting them in the car and trying to fight the parts together.
flex plate & torque converter gt43 Transmission - Rearend 2 01-12-2010 07:25 PM
Flex Plate Holes Dont Match Torque Converter mightycarlo10 Transmission - Rearend 3 03-07-2008 07:37 PM
flex plate bolt torque mike bryan Engine 1 11-14-2004 12:03 AM
700r4 torque converter to flex plate question BR57 Transmission - Rearend 6 10-05-2004 01:41 AM
flywheel torque = to flex-plate torque?? bullheimer Hotrodding Basics 2 05-26-2004 12:24 PM
