That is some good information.
I hope you don't have the same problem with the shroud, as I had with the "Vette" in my AVATAR. The radiator displaces so much heat it started to melt the shroud. I had to have a aluminum shroud made to fit. |
According to the specs, that's a pretty serious fan! 3300cfm@18amps.
The biggest thing that made the difference was probably the shroud. Not sure how well it would work were I live, summers hit 116+ and with A/C it might not make it. I"ve wanted to put electric on my truck for years, just can't justify the cost. |
I had very good luck with the flexalite's I used on my cars.
Kind of on and off topic, but I found an older 180 that's a 15" fan- not a 16"- but otherwise all specs are the same (CFM, Amp draw, etc). It should work just as well, wouldn't you think? Been sitting unopened in a box since 2003.
| flexalite 180 - 185 | brainsboy | Engine | 3 | 10-28-2008 08:34 AM |
| building a fan shroud - need help | 32Tudor | Hotrodding Basics | 30 | 07-03-2008 09:01 PM |
| Electric cooling fan | Z-Money Pit | Engine | 1 | 08-29-2006 08:27 PM |
| Need advice on a good electric fan set up. | Streetmaster | Engine | 13 | 01-07-2006 02:37 PM |
| Flex-a-lite 180 black magic X-treme fan anyone use one? | 72Nova383 | Engine | 6 | 10-18-2005 03:51 PM |
