Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Flexible Pipe from Compressor to Solid Pipe?
  #17 (permalink)
Old 03-06-2006, 03:44 PM
oldred oldred is offline
It might be easier to just put a TEE inverted in the lowest point of the dip and then add a "drop", a section of pipe about a foot or so long with a drain valve at the bottom. This will provide a place for the water to collect and be drained without being in the air flow, just be sure and drain it each time you drain the air lines.
