Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Garage - Tools
  #16
Old 03-06-2006, 02:19 PM
bluesman123's Avatar
bluesman123 bluesman123 is offline
re: Flexible Pipe from Compressor to Solid Pipe?
Man I am so glad I saw this post! I just ran a soft copper line from the comp through the shop the where the soft line starts, with a drier/filter just before the reel. Because this was an afterthought I have a big dip in the copper to get around some cabinets. Would it be better to add a drain valve to the dip or re-run the copper through the ceiling to get over the cabinet?
Dave
Old 03-06-2006, 03:44 PM
oldred oldred is offline
It might be easier to just put a TEE inverted in the lowest point of the dip and then add a "drop", a section of pipe about a foot or so long with a drain valve at the bottom. This will provide a place for the water to collect and be drained without being in the air flow, just be sure and drain it each time you drain the air lines.
Old 03-10-2006, 10:53 PM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Gassers were best!
I think you guys are making a bigger problem of this than it deserves. Any good quality 250psi rubber hose rated for water or air service will work. After all, that is all that is used for your air hoses that feed your air tools. Don't need any fancy ends, just cut the hose to length with a utility knife and slip it on properly sized barbed hose fittings w/ hose clamps. Shouldn't cost more than a few bucks and will last a lifetime.
Old 03-10-2006, 11:46 PM
robs ss robs ss is offline
 robs ss's barnstar
Willys 36
You're probably right, but theres a lot of different people on here that like to know the different ways to do things.
I know I overdo things, and it comes from a lack of confidence, probably my two older brothers, I'm trying to work around it.
I'm 64 years old, and I want to learn everything about these cars and how to fix them the.
Maybe you had a dad or brother or good friend that taught you how to do things, or maybe you learned it all by yourself, as for me I am self taught, and these forums are teaching me something every day.
The good part about this thread is all the different ways to run air lines, then a guy can just sort out how he wants to go.
If you could put some pictures on here, we could see how you do it.
Rob
http://webpages.charter.net/2manitowoc
http://www.2manitowoc.com/paintroom.html
Old 03-11-2006, 05:31 AM
I suppose one could argue that the air would be a lot hotter that near the compressor and thus the need for something a little more exotic than standard air hose and clamps and I imagine it would look a bit more professional but as Willys said an air hose should work just fine.
Old 03-11-2006, 06:59 AM
Kevin45's Avatar
Kevin45 Kevin45 is offline
Just one of the guys
I'm with Willys on this. All you need is a short piece of airhose with the proper fittings on the end. That's all I use and have used and it works just fine.
Kevin
Old 03-11-2006, 08:56 AM
kringold's Avatar
kringold kringold is offline
ATA Welding Technology
 kringold's barnstar
Me too. And personally I think sometimes it's the best way. Too bad we can't get a diploma for it!
As for what I use, an air hose from the compressor in the shed to the shop workbench with a water trap at the bench.
Old 12-03-2007, 06:47 PM
carguy68 carguy68 is offline
Compressor piping
I have set up the air lines in a couple of factories and have a couple of hints. Pitch the horizontal lines that run around the walls back to the compressor. This way the water can be drained from the tank daily. The tap off for the vertical lines should not be tee'd directly down from the horizontal line but should go up about 3- 4 inches and then down. This way any water in the lines will not go into the drop lines. The bottom of the drop lines should have a shut off valve then (going downward) a tee with the air line couplers and then an additional piece of pipe at least six inches long with a drain value at the bottom. The upper valve lets you shut off that drop. The last piece of pipe collects the condensed water and any debris in the lines and the drain valve lets it out.
Old 12-03-2007, 06:58 PM
Henry Highrise's Avatar
Henry Highrise Henry Highrise is offline
Moderator
 Henry Highrise's barnstar
Wiki Edits: 4
For the flexible conection from the compressor to the hard line...I always use double stainless braid hydraulic line....the stainless braid protects the rubber inner line and you know if it will withstand 3000psi of hot hydraulic fluid it can handle 150 psi of hot air.
Old 12-03-2007, 07:55 PM
Its been 18 months since I last posted in this thread, and I'll tell you what! Having a "significant" air compressor has truly changed my life! Just having a supply that is constant no matter what tool I am running has been worth all the issues with setting it up. Cap, you are right, that the cost of the compressor is just the start; but I don't mind. Now the $$ is spent, the lines are plumbed, I have a decent dryer........
Oh yeah...well, the Nova project? Well.....maybe it will be done soon.
Dave
Back to top
This discussion has been added to the Garage - Tools Discussions category of the Hotrodders Knowledge Base.
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Flexible Pipe from Compressor to Solid Pipe?"
air lines CARGUY Garage - Tools 96 11-16-2006 04:11 PM
hydraulic cams/lifters brian12c Engine 4 03-07-2005 08:46 PM
Exhaust Diameter Formula ChevelleSS_LS6 Engine 8 10-15-2004 10:03 PM
Airlines Kevin45 Garage - Tools 22 03-04-2004 04:35 AM
Is 2 1/2 pipes big enough? Mustang_Killa66 Engine 7 02-12-2004 08:04 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
