All,
Now that I have an air compressor I need to plumb some solid metal line (copper of black pipe) in the garage. I see several folks recommending a flexible metal line from the compressor to the start of the metal pipe to isolate the vibration of the compressor from the line? Where do you get this line?
My compressor has a 3/4 inch outlet to which I have attached a 3/4 inch ball valve, and I plan on using 3/4 inch copper pipe so obviously I want a 3/4 inch flexible hose of some kind?
In addition, where do you guys hook up your air regulator - at the tank's ball valve outlet or at the end of the metal lines where the rubber hoses connect?
Thanks,
Chris
Thanks,
Chris
