Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Flexible sanding blocks
  #29 (permalink)
Old 02-26-2012, 12:33 AM
mr4speed mr4speed is offline
There is a plastics business nearby that I get all the peices I need, they cut them to length right there. I think the last time I was there they cut up several shapes and thickness for around 15 bucks. I don't know where you are but if you look into any companies that specialize in plastics they should be able to help you out. I find the plexi works real well in various situations. I have one that is about 1/16 thick 2 3/4 wide by about 8 inches long and stays perfectly flat to whatever you bend it around to block something curved. Then for blocking round inside curves I use different sizes of pvc pipe.
