Flexible sanding blocks - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2003, 05:06 AM
New Member
Post Flexible sanding blocks
I am new to body work and I am wondering if any one as an opinion on flexible sanding blocks? I am working on a 41 Ford truck with lots of contours and I don't think I want to use a hard block sander, I found in the Eastwood catalog two flexible sanders (pg.42), an adjustable flexible sander and a flexible board sander. The adjustable one may better due the range of paper 80 grit to 2000 grit (body filler to color sanding) any ideas?
Old 01-28-2003, 06:07 AM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
No need to get fancy and order out. Just go to your local paint shop and get a few of the black closed cell foam rubber pads made by 3M($0.99each). They are what you need and they double for a squeegy too.
HK
Old 01-28-2003, 08:40 PM
mitmaks's Avatar
Last journal entry: Grille
Post
ya hes right or ....ebay...lol u can find good deals there on auto body tools & supplies, i hate eastwood prices are OUTRAGEOUS, gun that i got for 19.99 they sell for $50 what a ripoff
Old 01-28-2003, 09:41 PM
Post
Those 3M foam pads work real good they solved a lot of problems for me. Eastwood has some realy neat stuff but mitmaks is right they are a mite pricy.I can almost always find the same things {or very close to it} at local paint stores or auto parts for less money. however I must add that I have been pleased with the few items that I have ordered.
Old 07-19-2005, 11:56 AM
Dura-Blocks
Edited by willys36@aol.com
Sorry to do this to your thread Durablock but your advertising posts violate our strict no advertising policy on the forums. You are free to put ads in the classifieds section. Please read the 'New Member' posts at the head of each forum.
Old 07-19-2005, 12:25 PM
rrmccabe's Avatar
GM Muscle
I have to agree on the dura-block. I bought a set yesterday and they are the BEST I have used. I have many 3M pads soft and hard but they really dont work that great for blocking guidecoat.
I think the dura block site would be better served to add better photographs to the site. Some are really hard to tell. Dont click on the large kit for a picture
Also be nice if they had a block with a large radius on just one side for sanding up to fender lips.
Rich
Old 07-24-2005, 02:17 AM
Flame Artist
I have to agree I have the 2 long dura blocks and I love um, you just have to be careful that the ends don’t dig in and leave your old paper on it when not in use so dust dont get on the paper side, it really takes a different touch to get used to but once you do there great for those curves.
Rick.
Old 07-25-2005, 10:23 AM
Oops
Sorry, New to this,, ill remember this from now on.
Old 07-25-2005, 07:12 PM
Adjustable Flex sanders
IMO much better then the durablock...Eric
Old 07-25-2005, 08:52 PM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
I have the durablocks and have been pleased with them, however that does not mean there is not better or just as good out there
Old 07-26-2005, 04:50 AM
302 Z28's Avatar
Yesterday I used the two long foam Durablock's to block my fiberglass deck lid. I had two heavy coats of polyester primer on it and wanted to block it getting ready to apply some 2K primer. I cannot imagine an easier blocking system than the Durablock. I was also using the 3M guide coat system and it worked great also. The hard foam blocks conformed perfectly to the curvature of the deck lid allowing full sweeps from one corner to the other and from top to bottom., great product IMO.
Vince
Old 07-26-2005, 06:45 PM
skeeveman's Avatar
I am the Antirice
Yeah, the dura-block stuff is great. Got a set a few months back. When the paint supply guy came to the shop on his bi-weekly schedule, we were shown a set. My uncle nabbed the whole box of them up for like 50 bucks, all the blocks come in handy, especially the 1" tube block, and the 11 and 18 inch blocks. They are really nice to work with, it's all i've been using to block out the chevelle with, and it's been working out really nicely.
Old 01-12-2011, 07:38 AM
Flexible sanding tools Flexicat tools
Hi, try to flexible sanding tools from www.flexicat-tools.com
Old 01-12-2011, 08:34 AM
"I am new to body work and I am wondering if any one as an opinion on flexible sanding blocks? "
I think you will find that you will use different hardness blocks for each step of your work from walnut to soft foam sanding pads. Wooden blocks can be made to any size or contour. Check your local paint store for different hardness blocks OR an upholstery shop for foam rubber scraps.
"Hi, try to flexible sanding tools from www.flexicat-tools.com"
A new sanding 'shoe' for a long-board air sander will do the same thing cheaper and it's available at the paint store.
1) Do NOT sand down too far with each grit, you need to remove the heavier sand scratches with the finer grits.
2) use the softer pads with finer grit paper.
Have fun with it
Old 01-12-2011, 08:49 AM
Have fun with it
A long board air sander is good option but it seems to me that
www.flexicat-tools.com has much longer tools especially for two people.
Do you thing it is possilbe to get any 70" long board?
