flexplate - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2007, 11:52 PM
flexplate
Been in the automotive repair industry for 31 years, My son has my old 72 el camino donw in L.A. he was rear ended shortly after the 700r4 failed, a trans shop down there fixed it under the insurance. and shortly after he started complaining of an engine knocking under load, just tonight the gear reduction starter started not meshing with the flexplate. of course he wants me to diagnose the problem over his cell phone. Im thinking it is a Cracked Flexplate. any other explaination that may come to mind ?
Old 03-19-2007, 08:08 PM
Crosley's Avatar
Wiki Edits: 1659
cracked or broken flexplate is possible.
Starter problem?
Engine knocking under load..... are you talking of 'pinging' or an actual 'knock' like metal to metal??
72 pontiac flexplate powerrodsmike Engine 2 08-07-2005 12:47 PM
Problems bolting TCI Converter to TCI Flexplate Ghetto Jet Transmission - Rearend 2 06-19-2004 08:48 PM
Ford Flexplate spacing k2mooch Transmission - Rearend 9 01-05-2004 02:51 PM
351 windsor flexplate FAIRLANE DUDE Transmission - Rearend 1 01-16-2003 12:55 PM
Small Block Chevy 400 flexplate install novajohnb Engine 2 10-31-2002 03:53 PM
