flexplate - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2007, 08:05 PM
flexplate
I Have 64 Ford Galaxie W/289 Motor Auto C-4 Trans. I Had Motor Rebuilt And The Flexplate Had Some Wear On It So I Went To Parts Stor And They Said The 157t Should Be In There But 160t Came Out Of This C-4 I Matched Them Up And It Looked Fine So I Put It In And Had No Problem Yet, My Ques. Is ,is This O.k. To Do Or Will A Problem Be Made. Thanks John, New Member
Old 10-07-2007, 08:56 PM
If it starts and the converter fit...run it!
There is no access to 160T flywheels for small block....
72 pontiac flexplate powerrodsmike Engine 2 08-07-2005 12:47 PM
flexplate for 54 BEL AIR TATFINK Engine 4 01-30-2005 08:58 AM
Problems bolting TCI Converter to TCI Flexplate Ghetto Jet Transmission - Rearend 2 06-19-2004 08:48 PM
Ford Flexplate spacing k2mooch Transmission - Rearend 9 01-05-2004 02:51 PM
Small Block Chevy 400 flexplate install novajohnb Engine 2 10-31-2002 03:53 PM
