Flexplate - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2008, 07:28 AM
Flexplate
What did a 153 tooth flexplate usually come stock in? thanks
Old 11-03-2008, 09:12 AM
153 teeth
Any late 60's chevy could have come with either 153 or 164 tooth flexplates. Chevelle is one, the starter also has a different nose cone with a different pattern, 164 tooth starter has an offset pattern, while 153 tooth has a straight pattern. I worked for Chevrolet for 12 years. Any good parts person will be able to get you the right set up, Hotrodhill.
Old 11-03-2008, 09:39 AM
Thanks for the reply
Old 11-03-2008, 09:51 AM
I seriously doubt you SOLD any 164 tooth flexplates
The two sizes are 153 tooth or 168 tooth
Old 11-03-2008, 01:16 PM
flexplate
My mistake. 168 is correct.
Old 11-03-2008, 02:44 PM
ALL is good ...
352 flexplate LS-57 Engine 3 12-28-2007 10:53 AM
72 pontiac flexplate powerrodsmike Engine 2 08-07-2005 12:47 PM
Problems bolting TCI Converter to TCI Flexplate Ghetto Jet Transmission - Rearend 2 06-19-2004 08:48 PM
Ford Flexplate spacing k2mooch Transmission - Rearend 9 01-05-2004 02:51 PM
Small Block Chevy 400 flexplate install novajohnb Engine 2 10-31-2002 03:53 PM
