Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - flexplate and balancer
Old 06-08-2004, 10:04 PM
chevyman06's Avatar
chevyman06 chevyman06 is offline
You need to use a flexplate off of the 400. THe 400 has an externally balanced crank, meaning that the flywheel is balanced, not the crank. I beleive that this information is correct, but you should check another source to make sure.
