Flexplate/Balancer internal or external balance? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2013, 10:03 AM
Hey guys, for any of you that might have read some of my previous thread about the 350///357, I sold that short block. Im having another short block built.
The shop needs me to order my flexplate and harmonic balancer so they can balance the assembly.
I do not know which type to order... these are the ones I have picked out but im trying to make sure.
The balancer is internal balance and the flexplate is external balance so I assume this is wrong.
Brand:Chevrolet Performance
Chevrolet Performance Harmonic Balancers 12551537 - SummitRacing.com
Manufacturer's Part Number:12551537
Part Type:Harmonic Balancers
Product Line:Chevrolet Performance Harmonic Balancers
Summit Racing Part Number:NAL-12551537
Engine Balance:Internal
Safety Rating:Not SFI-approved
Degree Markings:Yes
Outside Diameter (in):6.750 in.
Harmonic Balancer Material:Cast iron
Harmonic Balancer Construction:Steel
Harmonic Balancer Finish:Natural
Mounting Hardware Included:No
Quantity:Sold individually.
Notesesigned for timing pointer in the 2 o'clock position.
Brand:Hays
http://www.summitracing.com/parts/hay-10-025
Manufacturer's Part Number:10-025
Part Type:Flexplates
Product Line:Hays Heavy-Duty Flexplates
Summit Racing Part Number:HAY-10-025
UPC:084041100257
Ring Gear Tooth Quantity:168-tooth
Rear Main Seal Style:1-piece
Engine Balance:External
Flexplate Material:Steel
Safety Rating:SFI 29.1
Notes:With counter weight.
Old 01-22-2013, 10:15 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Depends on if you have a 1- or 2-piece rear main seal crankshaft. 1-piece uses an external flex (http://www.summitracing.com/parts/hay-10-025 is correct).
Both 1- and 2-piece RMS 350 sbc use an internal damper, the one you linked will work.
The Following User Says Thank You to cobalt327 For This Useful Post:
0trbo4myCHEVUICK (01-22-2013)
Old 01-22-2013, 10:17 AM
What is the description of your crank?
The crank is usually intended to be run either internally or externally balanced, and sometimes can differ from front to rear, but without knowing that you are just guessing on what parts to get. The balance shop should be able to give you an idea, but they may need to spin the assembly to find out.
Old 01-22-2013, 10:46 AM
the block is a 1pc rear main seal 4bolt roller provisioned block. The crank is GM STEEL
Old 01-22-2013, 10:52 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
One good thing is the bolt circles/patterns differ between the two: smaller circle for the 1-piece crank and larger for the 2-piece "traditional" crank. Makes inadvertently using the wrong one impossible.
Old 01-22-2013, 11:14 AM
Okay well Im going to buy the ones I had listed and ship them directly to the machine shop.
After taking my previous short block to the shop and hearing him tell me the pistons where .043-.047 in the hole I decided to just sell the thing and start over.
Im having this one built with D cup keith black hypers 1.561 comp. height.
Keith Black KB Performance Pistons KB142-030 - SummitRacing.com and a decked block for
.010 piston to deck clearance.
Its a 4bolt instead of 2, steel crank, lt1 or X rods with arp rod bolts. All balanced. So im happy! Should be far better than the previously purchased short block. Ill post pictures as soon as I get it at my door in the crate. Gonna take 4 LONNG weeks though!
Old 01-22-2013, 11:55 AM
bondo's Avatar
Ayuh,.... Does this new block have the staggered starter bolt pattern,..??
Ya Need it to use the 168 tooth flywheel/ flexplate...
Old 01-22-2013, 12:02 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Sounds good!
You likely are aware of this already, but your KB hypers require a wider-than-normal top ring gap. More: KB Pistons for Automotive Applications
Old 01-22-2013, 12:09 PM
Sounds good!
Yeah I saw the "special instructions" for the pistons. I will mention this to the shop but hopefully they are aware.
I do not know about a "staggered starter bolt pattern"
I will call and ask.
Old 01-22-2013, 12:37 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You will need to match the flexplate/flywheel ring gear tooth count to the type of starter you want to use.
The larger flywheel has 168 teeth (about 14" OD) , and uses a starter w/offset mounting holes.
The smaller flywheel has 153 teeth (about 12-3/4" OD) and uses the starter w/the mounting holes straight across from each other.
Most all blocks are provisioned w/holes to mount either starter, but check to be sure that you have the holes and that they aren't stripped or broken.
Here is are some photos.
Old 01-22-2013, 12:43 PM
All SB Chevy engines with a 1-piece rear seal are internally balanced. They are equipped with a counter-weighted flex plate. The counter weight on the flex plate is to compensate for a rear main that does not have a counter weight. The counter weight on the flex ,plate does not mean the engine is "externally balanced".
Always use a neutrally balanced harmonic damper on a engine that is internally balanced. I used a pioneer 872021 damper. It is 6.100" O.D. and is SFI 18.1 approved.
Why would anyone use hyper-eutectic cast pistons in a high performance engine when eutectic forged pistons are available?
Old 01-22-2013, 01:06 PM
[QUOTE=MouseFink;1637637]
I dont see any neutrally balanced dampers made by GM? How come I cant use a internally balanced damper on an internally balanced engine?
Old 01-22-2013, 01:09 PM
Or are internal and nuetral balance one in the same?
Old 01-22-2013, 01:39 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
They're the same thing.
Old 01-22-2013, 04:23 PM
Thanks alot fellas
Internal vs. External Balance 68NovaSS Engine 17 06-12-2010 07:57 PM
Converting SBC External Balance to Internal Balance zildjian4life218 Engine 3 02-18-2010 02:02 PM
Internal External Balance MHenricks Engine 10 08-22-2009 09:37 AM
balance-internal or external 6speedwagon Engine 5 03-27-2005 08:36 AM
Internal vs External Balance 614streets Engine 3 05-28-2003 02:25 PM
