Flexplate bolts? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2010, 09:55 AM
Madmax305's Avatar
Flexplate bolts?
OK, I'm in the process of installing a Hughes 3000 stall in my 67 El Camino. I pulled the flexplate off and inspected it and it looks fine. I will be using arp flexplate bolts, my questions are; Do I torque them in a star pattern? What do I torque them at and do I use any anti seize, motor oil or lock tite?
Second, how tight do I get torque converter to flexplate bolts and do I use lock tite on them?
Old 11-10-2010, 10:49 AM
tnsmith10's Avatar
when will it rain???
its not a bad idea to tighten the flexplate bolts in a cross or star pattern, i recommend that the blue thread sealer be used instead of the red locker, for both the flexplate and converter to flexplate. 30 ft lbs. is sufficient for torque for the converter. make sure you have the converter flush up against the flexplate before tightening any of the converter bolts.
Old 11-10-2010, 12:49 PM
sqzbox's Avatar
My pipes are my music
What about the third question?
Old 11-10-2010, 12:55 PM
sqzbox's Avatar
Ok, I got it now. He asked the second question twice. Right?
Old 11-10-2010, 03:36 PM
SSedan64's Avatar
Also, make sure you install the TC correctly. Turning & pushing, should feel/hear 3 clicks, Input shaft splines, Stator splines & Pump lugs/splines. Should be 1/8" to 3/16" between Flexplate & TC before sliding forward to tighten TC bolts.
Old 11-10-2010, 06:19 PM
Madmax305's Avatar
Thanks for all the replies guys. I got it installed and works great.
Suspension torque specs scr8pin_f100 Suspension - Brakes - Steering 3 12-31-2008 06:46 AM
Body alignment 1949HevyChevy Body - Exterior 2 11-12-2008 04:49 AM
"Bowed" deck lid cruzinTLT Body - Exterior 3 03-04-2005 09:24 PM
body parts fitting anyoldchevy Body - Exterior 10 02-20-2005 09:20 AM
Removing flywheel to converter bolts in a 1958 Chevy Impala 348 Cast Iron Powerglide 1958imp348 Transmission - Rearend 9 11-22-2004 03:18 PM
