Flexplate Clearance - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2006, 02:55 PM
DeathRattle's Avatar
Some Punk Kid
Flexplate Clearance
How tight is too tight on a flexplate? I have a 168 tooth plate and it leaves about 1/4" (or a little less) around a th350 bellhousing. Should I downsize to a 153?
Old 11-24-2006, 03:40 PM
Some Punk Kid
after actually bolting bell to block The exact measurement is 1/8" clearance from closest edge of tooth to closest bell bolt hole casting (that comes in on an angle).
Old 11-24-2006, 07:23 PM
your clearance is fine.
That's the way it is.....
Old 11-24-2006, 08:27 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
Well the way I see it, If it is not touching now something pretty bad is going to have to happen to make it touch. Right?
Starter flexplate clearance Not A T 25 Transmission - Rearend 8 05-24-2006 12:27 PM
72 pontiac flexplate powerrodsmike Engine 2 08-07-2005 12:47 PM
Ford Flexplate spacing k2mooch Transmission - Rearend 9 01-05-2004 02:51 PM
TH 350 Intermediate clutch clearance 1969Chevelle Transmission - Rearend 1 08-26-2003 04:34 PM
Small Block Chevy 400 flexplate install novajohnb Engine 2 10-31-2002 03:53 PM
