-   -   Flexplate cover for 2004R 4.3 V6 (http://www.hotrodders.com/forum/flexplate-cover-2004r-4-3-v6-211153.html)
T Evans 12-28-2011 10:43 AM
I'm looking for a flexplate cover that will fit a 1986 TH2004R that I'm putting on a 1994 4.3 V6 engine. Thanks for any help. Tom
S10xGN 12-29-2011 08:34 AM
That's usually the 1st thing I "delete" from a build...
Russ
whyholdback 12-29-2011 08:41 AM
Forget it, it contributes nothing worthwhile to any street-only vehicle. Heat is the enemy of automatic transmissions, and deleting that stupid cover will help the converter shed some heat. Maybe not a lot, but some.
Also, with the bottom of the flexplate exposed, there's a slight hope of skinning the backs of those annoying cats who hide under your vehicles.
S10xGN 12-30-2011 09:28 AM
Someone here once brought it to my attention that the shield is there to keep rocks, trash, etc from becoming lodged between the converter and housing or flexplate and block. A moot point for me since I never drive on anything but clean pavement...
Russ
T Evans 12-30-2011 10:52 AM
I still would like to know what cover fits
I still would like to know what flexplate cover will fit a 1986 TH2004R mated to a 1994 chevy 4.3 Vortec V6. I am debating to leave it off, but I may opt to put one on. Thanks for the replies. Tom
artsvettes 12-30-2011 11:41 AM
When I did my 2004r swap, I used the cover from the THM350. One hole needed a little massage. Any V8 with the thm350 besides the truck aluminum covers should work
SSedan64 12-31-2011 12:44 AM
Any car that came with a SBC/SmallBlockChevy Engine & 2004R Trans the cover should fit the 4.3L V6 w/2004R. 82-90 Models, G-bodies & larger B-bodies. Other TC covers fit with slight Mods as Art said above.
