flexplate issues on a 350 chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2010, 11:48 AM
come to find out i have a warped flexplate on my 87' 350, what cause that? im getting ready to pull the tranny out to replace the flexplate, so far iv got the exhaust droped, and the driveshaft out, and to find the pinion seal leaking, and while iv got the traany out, fix the small leak it has aswell.. Any ideas on how the flexplate got warped?????? and one more ?'s, does the weight on the flexplate face the engine or the tranny??????
Old 06-15-2010, 12:23 PM
GT_80's Avatar
Wish I had more time and money
One possible explanation for the flew plate being bent is if the center of the torque converter doesn't fit INSIDE the rear of the crankshaft- this will cause the flexplate to pull away from the motor to mate with the torque converter. The torque converter should sit completely flush against the flex plate before the bolts are inserted. I have had one that i had to file down the center of the torque converter to slide into the flex plate.
The flex plate should have a lip on one side of the center hole where it goes over the rear of the crankshaft. The lip faces the transmission when installing- they may have "motor side" or "Trans side" stamped into the flexplate as well.
Hope this helps
Old 06-15-2010, 12:35 PM
How did you "come to find out" ?...What symptoms did it display?
Old 06-15-2010, 12:37 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I've seen flexplates get warped from guys using a prybar and too much force to remove it from the end of the crank- sometimes it's on there tight enough to require some heat to easily remove it. Too much heat will also warp one.
Old 06-15-2010, 04:48 PM
i was hearing a tapping noise, not like a bearing or that sort of things, so while it was running i looked under the car @ the converter and flexplate, the flexplate was wobbleing, so thats looks like a good place to start!
Old 08-06-2015, 05:08 PM
I know I'm quite late to this discussion, but I experienced the same wobbly flex plate. Did it damage your torque converter?
Old 08-06-2015, 06:09 PM
One foot on the brake and the other mashing the throttle to the floor is what usually does this.
The ring gear sometimes ends up kissing the starter pinion so you hear a tick.
Bogie
Old 08-06-2015, 06:49 PM
Show me the money !
I had the same knocking noise happen to me.. scared me half to death. ( new motor ) ..Turned out the tranny bolts were loose and ended up cracking the flex plate.. Could have been worse !
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
is this Pontiac or Chevy 350 GMR Engine 8 03-31-2009 06:28 AM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 03:45 PM
Chevy 350 Off Idle Issues! 84Caprice57 Engine 5 02-01-2007 09:50 AM
Small Block Chevy 400 flexplate install novajohnb Engine 2 10-31-2002 03:53 PM
