Flexplate question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2011, 01:10 AM
Flexplate question
Ok so i have a 350 hecho en mexico 3970010 block i was told it was a crate engine when i picked it up. It needed some parts to get back together. I got a flex plate for free from a dude in state. He told me its off his 90's suburban its a larger 168 tooth. My major question is I've read there are differences in one piece mains an two piece main flexplates. Will the flex plate i got work on my 350. The flex plate is balanced on the plate. The number on it is 10101170.
Old 08-16-2011, 05:33 AM
Flexplate puzzle
The 168 tooth flex plates are 14.13" O.D., use a starter with offset bolts and the 1987 - up flex plates have a 3" crank flange bolt circle, have a counter weight for a internally balanced engine and fits the crankshafts with a one-piece rear seal.
Some of the SB Chevy flex plates have a 10.75" diameter torque converter bolt circle, some have 11.50" diameter torque converter bolt circle and some have both bolt circles. My 700R4 transmission uses a flex plate with a 10.75" torque converter bolt circle. A TH-350 and TH-400 must be checked because those transmissions could have either a 10.75" or a 11.50" torque converter both circle.
The 10101170 flex plate fits a 1991-2000 BB Chevrolet with a cast iron crankshaft and has 168 tooth starter ring gear. That is all I know about that one.
Old 08-16-2011, 05:41 AM
the crank register is smaller on a one piece seal crank and they are externally balanced.
Old 08-16-2011, 12:54 PM
so is that a no it wont work? cause im using a t-350 so do i need a smaller flex
Old 08-16-2011, 02:36 PM
Flex plate puzzle II
You need to get the correct flex plate for your application. Unfortunately, you may have to actually look and see if the block uses a 1-piece or 2-piece rear main seal.
You will need to use a starter with off-set mounting bolts and the flex plate should be:
GM - 471598
flex plate for a 2-piece main seal, 14.13" OD, 3.58" crank flange bolt circle, 168 tooth starter ring gear, no counterweight, 1970-1985. .
or
GM - 14088761
flex plate for a 1-piece main seal, 14.13" O.D., 3.00" crank flange bolt circle, 168 tooth starter ring gear, with counterweight, 1986 - up
Since those flex plates have a 10.75" and a 11.50" diameter torque converter bolt circle, they will fit any TH350 or TH400 torque converter.
bbc flexplate question yevgenievich Engine 1 05-07-2009 08:24 PM
flexplate question goshawks00 Engine 1 11-02-2007 09:14 PM
Flexplate question here. Bryan59EC Engine 3 10-12-2007 06:56 PM
Question about flexplate 92z28400sbc Engine 7 10-10-2006 05:42 AM
Help, flexplate question La Maquina Transmission - Rearend 3 09-04-2003 03:10 AM
