flexplate question - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2011, 09:57 PM
B.A.M.F
flexplate question
sbc 388 stroker scat lightweight forged internals 12.5:1 CR top und rpms around 8500 rpms what kinda flex-plate do i need to run and how many teeth?
Old 12-30-2011, 11:18 PM
327NUT's Avatar
Depends on your starter location but most use the 168 teeth FP, you can buy a new Scat SFI part on ebay for around $40.
Old 12-30-2011, 11:48 PM
B.A.M.F
lol that's what i was actually wondering bc i was looking on eBay and found some brand new unopened 168 tooth scat one for a 400 sbc and i don't know what the diff is in flex-plates from a 350 to a 400, can anyone enlighten me?
Old 12-30-2011, 11:50 PM
B.A.M.F
i guess i should take converter size into account too correct? i plan on running an 8in converter with high stall
Old 12-31-2011, 08:17 AM
flexplate response
The only diff in a sbc 400 & 350 flexplate is that a 400 flexplate has weights on it & works in conjunction w/ a 400 harmonic balancer to balance sbc 400 engines.
Old 12-31-2011, 03:06 PM
Since the 383 type motor uses a 400(3.75" stroke) crank to achieve the extra cubes, you need the 400 style flexplate for your motor to be balanced correctly, ... unless, you spent big bucks on an internally balanced crank assembly.
Flexplate question matt921 Transmission - Rearend 4 08-16-2011 03:36 PM
Flexplate question. Studebaker Engine 5 05-20-2011 06:36 AM
Flexplate question here. Bryan59EC Engine 3 10-12-2007 07:56 PM
flexplate question 84bird Transmission - Rearend 1 05-03-2005 09:03 AM
flexplate question 280zxWith305 Hotrodding Basics 8 02-03-2005 02:43 PM
