My engine is repaired and ready for assembling in the car. Last time i did sometimes notice a crying noise from the starter. I checked it an made these photos. Can it be, that's the clearance is to much?
That to much clearence, needs to be tighter. Should be pretty close to the thickness of paper clip wire. You can use different thicknesses of washers on the inside or outside starter bolt to get it closer. Can't remember which one, I've got it written down at home.
It is not uncommon that the starter base mount has to be machined .060" then use shims to get correct clearance. I used to do several every year. :thumbup:
Thanks for the replies. Starter is assembled without shims because shims will increase the clearance.
In my though the best solution is to mill the starter base 040-060" down.
My engine is a Buick 455 and its hard to find a starter back brace to block. I hope it will work with proper timing (MSD 6530 i can programm very less advanced timing while cranking) it will work without one.
Shimming the outboard bolt will tighten the clearance. Start by cutting a full length shim in thirds and using the two ends under the outboard bolt. Re-measure, and shim accordingly.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
