Flexplate starter clearance *picture* - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2014, 02:51 AM
Hi folks
My engine is repaired and ready for assembling in the car. Last time i did sometimes notice a crying noise from the starter. I checked it an made these photos. Can it be, that's the clearance is to much?
Any advices?
kinds regards
Robert
ID:	152874   Click image for larger version
Old 06-10-2014, 06:39 AM
Last journal entry: Still running strong
That to much clearence, needs to be tighter. Should be pretty close to the thickness of paper clip wire. You can use different thicknesses of washers on the inside or outside starter bolt to get it closer. Can't remember which one, I've got it written down at home.
Old 06-10-2014, 06:50 AM
BOBCRMAN@aol.com's Avatar
It is not uncommon that the starter base mount has to be machined .060" then use shims to get correct clearance. I used to do several every year.
Old 06-10-2014, 11:54 PM
Thanks for the replies. Starter is assembled without shims because shims will increase the clearance.
In my though the best solution is to mill the starter base 040-060" down.
My engine is a Buick 455 and its hard to find a starter back brace to block. I hope it will work with proper timing (MSD 6530 i can programm very less advanced timing while cranking) it will work without one.
Old 06-11-2014, 06:56 AM
Greg T's Avatar
www.krusinklassics.net
Shimming the outboard bolt will tighten the clearance. Start by cutting a full length shim in thirds and using the two ends under the outboard bolt. Re-measure, and shim accordingly.
Old 06-11-2014, 09:50 AM
The brace really makes a difference. Also check to see knurling on the bolts hasn't worn down. The knurling is there to keep the starter from shifting around.
TC to flexplate clearance Muley Transmission - Rearend 23 04-14-2014 03:31 PM
Starter gear to flexplate clearance 87SS Engine 7 07-22-2008 06:03 PM
Converter to flexplate clearance tfeverfred Transmission - Rearend 6 09-22-2007 09:05 AM
Flexplate Clearance DeathRattle Transmission - Rearend 3 11-24-2006 08:27 PM
Starter flexplate clearance Not A T 25 Transmission - Rearend 8 05-24-2006 12:27 PM
