Flexplate Tolerance??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2012, 05:22 PM
I'll try and make this as easy to understand as I can.
I notice during my test run (engine on a stand) that my flexplate did not seem to be perfectly flat. So, I removed it and laid it on a glass table to check flatness (straightness). I can slide a dollar bill under two opposite sides of the plate. So, should it be perfectly flat? How much tolerance in flatness is ok? I can afford to buy another one but if I can slide a bill under it also, do I keep on until I find one perfectly flat?
Thanks
Willy
Old 04-01-2012, 06:22 PM
I have seen flex plates with a lot more than a dollar bill out being flat for sure ..
Your torque converter will stiffen it up anyway
Old 04-01-2012, 07:37 PM
Thanks
Willy
If you had any doubt about it I would replace it. Its worth the cost of buying a new one to reduce the chance of ever having to pull that engine to replace it. Ive been there done that.
Fiberglass and Heat Tolerance scratchrod Hotrodding Basics 8 07-30-2007 06:35 PM
tolerance in pully alignment DaSouthWon Engine 8 12-17-2006 12:08 PM
piston tolerance Matts99Sierra Engine 4 01-30-2005 10:52 AM
LS1 block tolerance Mad Maggot Engine 2 10-18-2004 09:18 PM
Cam Wear Tolerance? 54 Chevy Engine 2 01-09-2003 01:30 PM
