flexplate to torq convertor bolts help. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2007, 07:56 PM
pi71's Avatar
i installed my transmission after installing a new flexplate , now im having hell trying to line up the flexplate and torque convertor to install the 3 bolts. any tricks i need to know about? thanks.
Old 08-08-2007, 08:16 PM
Is your torque converter all the way in? It should turn pretty easily to line up a bolt hole. They make a tool to grab the flexplate ring gear if you're having trouble turning it.
Old 08-08-2007, 08:54 PM
pi71's Avatar
yes the tc is all the way in , i got one bolt in but none of the others lined up so i guess you can be off, i guess ill just keep spinnin the crank till i get it.
Old 08-08-2007, 09:01 PM
Crosley's Avatar
Wiki Edits: 1659
Mopar converters often have an un-even bolt pattern spacing....
spin the converter around as you mention
Old 08-08-2007, 09:27 PM
what transmission is it
Shane
Old 08-08-2007, 10:33 PM
pi71's Avatar
torqflite 904 in a 78 postal jeep with an audi 4cyl..
chevy 383 bent flexplate? 49chevysd Transmission - Rearend 3 01-07-2006 12:22 PM
72 pontiac flexplate powerrodsmike Engine 2 08-07-2005 12:47 PM
Problems bolting TCI Converter to TCI Flexplate Ghetto Jet Transmission - Rearend 2 06-19-2004 08:48 PM
Ford Flexplate spacing k2mooch Transmission - Rearend 9 01-05-2004 02:51 PM
Small Block Chevy 400 flexplate install novajohnb Engine 2 10-31-2002 03:53 PM
