Flexplate weights - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2011, 09:49 AM
Babyburr's Avatar
Flexplate weights
Do all flexplates for a chevy 350 have to have a weight welded on it?
Old 04-21-2011, 10:38 AM
No.
All one piece rear seal engines have a balance weight, with a different amount of imbalance for a 4.3, 5.0 and 5.7, so make sure to get the right one.
Of the GenI SBC, only the 400 engine had an external weight in stock configuration. Any external engine can be converted to an internal balance engine wand would then use a neutral, or unweighted flywheel.
Old 04-21-2011, 10:14 PM
Babyburr's Avatar
Thank you, sir, for the good info.
I need car weights!!!!!!!!!!!!!!!!!!!!!! bigbad66chevelle Engine 17 02-20-2010 09:32 AM
different HEI weights??? yragat Engine 3 11-16-2008 04:55 PM
T/A weights t/a clone Hotrodding Basics 1 07-12-2005 11:52 PM
flexplate balance weights Hooter Transmission - Rearend 0 07-05-2004 03:57 PM
Piston Weights KeithB123 Engine 4 12-14-2003 11:34 AM
