Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Flip/flop & Candy Colors
Old 11-07-2004, 08:39 PM
mrcleanr6's Avatar
mrcleanr6 mrcleanr6 is offline
alot of the stuff is just like house of kolor's with dry pearls and flakes that you add to your clear as well as the candy concentrates. the only thing a little different that the base colors are in concentrated form also. you should be able to use all their stuff with your ppg line. i have used the flourescent pigment before and you just mix it into any clearcoat. worked great.
