Flip top hingesenders - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2011, 07:29 PM
Gentlemen: I'm building a '74 Vega for the drags, I bolted and welded the hood, both fenders, and the front together, My question is does anyone have an idea about making hinges to make flip top to come forward? Thank You
Old 01-21-2011, 05:50 AM
Wiki Edits: 27
roll then tilt
The neat one I saw had round tube each side running foreward, the hinge mechanism was mounted on the roller mechanism. The front end moved foreward so it would clear everything then tilted. and was operated by an air cylinder.
Old 01-21-2011, 10:15 AM
evolvo's Avatar
Heathen
I saw one once where a guy had used some of these.
http://new.chambrelan.com/US/telesco...FQqAgwodvnNOHw
Old 01-21-2011, 12:50 PM
dinger's Avatar
I did a search right here on good ole HR.com. This ought to help some:
Front end/fender tilt kit for 39 for doupe
Good luck. Powerrodsmike has done a nice one on the 41 Plymouth, the car won a bunch of show awards. I saw the car in Kingsburg, Ca. and Mikes shop, nice work.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Body flip Toto Body - Exterior 2 12-27-2008 11:53 AM
rearend flip kleen56 Suspension - Brakes - Steering 1 05-11-2008 08:52 PM
Flip this car the next bubble to pop? Magnus_Jager Hotrodders' Lounge 16 10-09-2007 07:33 PM
Rear end flip?? 66chevysb Transmission - Rearend 7 01-17-2006 11:31 AM
Flip Nose TOMO General Rodding Tech 2 09-03-2005 02:53 PM
