Flipping leaf spring - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2007, 02:48 PM
cboy's Avatar
Last journal entry: Finished
We've discussed this car with it's flipped over chassis on a number of other threads but I have a question about the way the leaf springs are set up.
It appears to me the leaf springs are being asked to work opposite of how they would in traditional set up. In this picture the "force" is working WITH the curvature of the main leaf and all of the sub leafs are located inside the curvature.
In a more normal set up (like the front of back of a T-Bucket) the "force" is working AGAINST the curvature of the main leaf and the sub leafs are located on the outside (or above, in the case of a T-bucket set up) of the curvature.
My question is, does it make any difference? Will the leaf spring work as effectively whether the curvature works with the force or against the force. And if so, does it also apply to quarter elliptical leaf springs?
(Hope this makes sense...I don't know my spring lingo very well.)
Always learning...and sharing what I've learned.
Old 02-28-2007, 03:18 PM
poncho62's Avatar
Wiki Edits: 5
I agree....with the springs upside down like that, you had better have them clamped together good, because all the force is against those thin straps. I think the person that installed those didn't think of that. The main leaf is doing most, if not all of the work.
Old 02-28-2007, 04:08 PM
Wiki Edits: 49
You know..... there's being different and then there's being weird. You have to wonder what the spring action would be like if he ever hit a pot hole.
Old 02-28-2007, 04:29 PM
steve t's Avatar
ex biker, now hotrodder
what is with those front tires, big is ugly ok i see now, it would drag the ground, still ugly
Old 02-28-2007, 05:35 PM
S10xGN's Avatar
Gotta love a turbo!
Completely unsafe! If a tire ever blew, that thing would be seriously dragging frame!
Russ
Old 02-28-2007, 05:56 PM
cboy's Avatar
Sorry. Maybe I used the wrong picture/example to clarify my question. I really didn't want to get into another discussion about the looks, safety etc. of this particular car.
My question was a more technical one. Do leaf spings provide the same spring rate in either direction - going with the curvature of the spring or against the curvature of the spring (assuming the supporting secondary leaves are stacked on the appropriate side of the primary leaf each time.
Old 03-01-2007, 12:50 AM
aka Duke of URL
The theory is a little beyond me but heavy truck use inverted springs on the tandems (MACK-TIMKEN).
I don't know about this though. I guess as long as a shackle kit allows the spring asm. to expand/contract...
Old 03-02-2007, 10:11 AM
Last journal entry: Lessons learned, how to's, etc...
I did mine a little differently than he did, but it works good, no problems with potholes. His (above picture) biggest problem is that, as someone correctly pointed out, his frame'll drag if he blows a tire. My axle is under the springs, and my springs are de-arched to keep the front up, and it won't drag if I get a flat. Google American Underslung sometime.
pics: semi-recent, and early in the process (lots of trial and error to get it where it is now).
ID:	18985   Click image for larger version
Old 03-02-2007, 10:18 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Originally Posted by cboy
Sorry.
Yes, they are the same.
If you flip the springs as he did, just rearrange the leaves from the outside of the arch to the inside, restacking in sequence, and the spring rate is the same but working in the opposite direction.
Looking carefully you will see that when the axle moves up away from the frame in normal comression thus increasing the arch, the spring is compressing all the leaves in the same manner as the inverse style.
This works for any leaf spring, semi-eliptical or quarter-eliptical.
Old 03-02-2007, 12:03 PM
cboy's Avatar
Excellent xntrik. Exactly the info I needed. I may not do the flipping, but it allows me a lot more design flexibility to know I could install the springs in either configuration.
Old 03-02-2007, 12:13 PM
cboy's Avatar
Originally Posted by PharaohChris
I did mine a little differently than he did....
Thanks for the pics. I can understand how you would have to do a bit of trial and error to get the final ride height correct. I'm trying to design some "adjustability" into my front and rear suspensions so that I'll be able to correct for the spring rates/compression etc. without having to tear everything apart once I discover I'm either riding too low or too high.
BTW, I'd enjoy seeing some additional shots of your rod and some close ups, particularly the suspension work. Maybe start a journal or just post them up in your photo gallery and then PM me.
Dewey
Old 03-02-2007, 09:12 PM
to my understanding a leaf spring needs to have compression to work ...this cars spring set up will not compress under any driving situation .the springs are only holding up the frame and the car will handle the same as if the axle were welded to the frame.
Old 03-03-2007, 12:07 AM
I don't think that works at all, Who built that thing???
Old 03-03-2007, 01:04 AM
Springs work just fine with negative arch as long as they are made that way. Running a spring with negative arch will change your anti-dive, roll center, and the axle roll axis. In RCVD (Milliken & Milliken's Race Car Vehicle Dynamics) p.662 is a diagram on how to figure out all those things. Anti-dive won't matter because there are no front brakes , and with how low that thing is I doubt there is enough wheel travel that you would really care about the roll center or axle roll axis. The only thing I would really worry about would be the open part of the spring eye is looks to be on the bottom of the leaf. It should be on the top.
Old 03-05-2007, 07:49 AM
Speeking from three years of personal experience with the underslung design, I can assure you, you are wrong in your thinking. I wish I had a video camera so I could make a video of my front axle as I drove down the road. I'm quickly wearing the paint off the front cross member by bouncing on it at shows just to prove that the design works .
I know you didn't ask, but the underslung design came about in 1905...
Leaf Spring Data base nautius Suspension - Brakes - Steering 8 11-05-2006 11:25 AM
rear leafs to stiff 2112jb Suspension - Brakes - Steering 12 10-06-2005 07:29 AM
TCI's rear leaf spring installation gavinpierce Suspension - Brakes - Steering 9 06-23-2005 06:00 PM
Who makes a 52" x 1.75" leaf spring? jpd37 Suspension - Brakes - Steering 5 10-14-2004 11:59 AM
8 1/4 to 8 3/4 rear end Leaf Spring Problem... 71gtx Transmission - Rearend 21 04-19-2004 07:17 AM
