floor/firewall mounted or under floor/frame pedals? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2012, 01:48 PM
31ROC's Avatar
Part oy my winter project may be converting from 700R4 to 4-speed, and on a '31 Model A hot rod, should I be looking at the under-dash mount pedal/cylinder assemblies, or under the floor mount to the frame styles?
Thanks in advance.....
Old 11-20-2012, 03:53 PM
techinspector1's Avatar
Wiki Edits: 326
I like hanging pedals, but it's up to the individual's choice. Not sure if there's an advantage one way or the other, except depending on how they're mounted, floor mount may be easier to service (add fluid, etc.). If firewall mounted, then fill would be easy, but not too many guys like master cylinders hanging on the firewall. If mounted under the dash, that's where service gets tricky.
Old 11-20-2012, 03:55 PM
31ROC's Avatar
yes.....I agree with no cylinders on firewall, if mounted under dash, it could get tough to service?
Old 11-20-2012, 04:26 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I fthe master cylinder is under the dash how do you check fluid level and such..?? A's have a narrow firewall so there may be interference with the master cylinder and the left cylinder head with a v-8 installation..If you have an old master just hold it in various positions until you see where it fits and works fime taking into consideration servicing and operation..
Sam
Old 11-20-2012, 06:51 PM
31ROC's Avatar
Sam
Good point sam...I'm also gonna check out under the floor possibilities....Thanks
Old 11-20-2012, 08:07 PM
Dennis W. Parks
Personally, I would prefer to have the pedals mounted beneath the floor. You can always add in a remote fill for the reservoir(s) if necessary. Just something to consider.
Dennis W. Parks
author of automotive how-to books
Old 11-20-2012, 08:10 PM
life is a temporary assignment
I like hanging pedals....
Old 11-20-2012, 08:14 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
It depends. If you have outside the frame headers / exhaust then you'll have more space under the floorboards.
But if your exhaust is under the car, epecially if your running headers, and you are using a mechanical z-bar clutch set-up the firewall mount swing pedals are a better option.
And lastly, kudos to you for switching from an automatic to a manual....
Old 11-21-2012, 04:16 AM
31ROC's Avatar
any issues filling or servicing reservoirs?
Old 11-21-2012, 07:12 AM
S10xGN's Avatar
Gotta love a turbo!
With reverse mounted hanging pedals, you could remote-mount the reservoirs under the factory cowl vent and use the vent to service the fluid...
Russ
Old 11-21-2012, 05:24 PM
No problems, If it's on the firewall,,easy to get to,
Floor mounted Master cylinder siwel Suspension - Brakes - Steering 1 12-02-2011 10:48 AM
Firewall to Front Floor Pan Seam ??? Removal stanhope55 Body - Exterior 26 01-27-2010 07:50 PM
Firewall/floor clearence 1931gt General Rodding Tech 4 01-20-2010 11:41 AM
Floor mounted emergency brake by Lokar Countilaw Suspension - Brakes - Steering 7 02-09-2008 07:51 PM
Pedals goin to the floor cutsupreme Suspension - Brakes - Steering 10 10-06-2006 11:21 AM
