Floor jack rebuild. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-26-2010, 11:10 PM
garretthes's Avatar
Last journal entry: Rear Axle swap #2 (74 Camaro) part 6
Found a great "how to" doc online. Took about 45 minutes but my Michelin jack is working again!
  #17 (permalink)
Old 08-27-2010, 05:46 AM
So why not post where this doc is to help the next guy? Thanks-Jim
  #18 (permalink)
Old 08-27-2010, 10:05 PM
garretthes's Avatar
I was going to but it's a pdf file and I couldn't grab the link. Let me see if I can copy and paste the text.
  #19 (permalink)
Old 08-27-2010, 10:07 PM
garretthes's Avatar
Found another link to it.
http://newsgroups.derkeiler.com/Arch.../msg00014.html
  #20 (permalink)
Old 11-06-2010, 02:48 PM
hydraulic jack rebuild
Guys, As a rebuilder of floor jacks I will share some thoughts. First , China jacks are cheap because of poor quality. Most are impossible to get parts for, except NAPA.
Most fail within a year or two. The best use for them is a boat anchor. Now on the other hand, old American jacks are bullet proof, high quality if you can find them. Blackhawk, Walker/Lincoln, Hien Werner, etc. There are still rebuild kits available for them. The kits are usually between $50 and$100 on the net. Your local hydrulic repair company can fix it for you. Usually between $150 and $200. You will have a jack that will last another 20 years. Charlie
  #21 (permalink)
Old 11-09-2010, 12:12 PM
cranky1's Avatar
Just stuck
I have a couple of Lincolns and they both need kits and I bought them. Don't remember what I paid but don't remember them being very expensive. On the China made crap, I just add heavier oil to those POS's....usually makes them work again.
  #22 (permalink)
Old 11-09-2010, 12:59 PM
Coolball's Avatar
Last journal entry: First Entry 82' Camaro Z28 Project
Something I picked up from another thread was to use brake fluid to fix a leaky jack. Have an old Montgomery Ward jack that started leaking and it's been the best jack I've owned so I gave it a shot and it's worked for me so far after a few months. Seems to be you get lucky or you don't on rebuilding.
  #23 (permalink)
Old 11-09-2010, 01:29 PM
cranky1's Avatar
Just stuck
Brake fluid makes the seals swell....but it's not something that you should leave in it since most of the time, the seals will continue to swell....
  #24 (permalink)
Old 03-23-2011, 04:43 PM
Coneboy's Avatar
Here's a link to a GREAT "How-to" on floor jack rebuilding. Hope it helps! http://garagejournal.com/forum/showthread.php?t=51105
  #25 (permalink)
Old 03-23-2011, 04:51 PM
Coolball's Avatar
Confirmation on the brake fluid swelling the seals. It was a temp fix for about 2 months of heavy use and now it's back to leaking.
  #26 (permalink)
Old 03-24-2011, 06:26 PM
adamsautoadvice's Avatar
Adam's Auto Advice
I was going to suggest looking at that thread too!
  #27 (permalink)
Old 04-30-2011, 06:26 PM
Floor jack
I have the same floor jack, it's the blue Michelin 3.5 ton. Mine stopped lifting after I lifted mt super duty with it to rotate my tires. I found it also had a stuck valve, what I did was pulled the screw that is on the far right side (as you are standing with the handle in your hand), it will leak fluid....about a tbl spoon. I lifted the arm a little and let it fall back down, when I did the spring popped our and it freed up the stuck valve. It was also about a 1/4 cup low on fluid, I used DOT 3 brake fluid and mine is working great!
TonyG (the other TonyG)
Hope this helps.
  #28 (permalink)
Old 05-04-2011, 06:38 PM
Maxwell007's Avatar
Try this....has tons of good info.
http://www.garagejournal.com/forum/s...ad.php?t=36252
  #29 (permalink)
Old 05-04-2011, 08:08 PM
Anything on that forum by Hiball will help, he can also point you in the right direction for parts/kits as well.
Funny how all us junkies end up on the same websites...lol
Carb rebuild - won't start now. Please help? joe99 Engine 6 11-30-2011 03:04 PM
Please help me find T-350 rebuild kit, what do I need? Warrant Transmission - Rearend 9 05-04-2006 10:46 PM
C-4 65 Mustang Tranny Rebuild 65Mustang289HIPO Transmission - Rearend 13 05-02-2006 12:47 PM
Which rebuild kit? leastbay Engine 7 12-19-2004 03:19 PM
q-jet rebuild kit Blob Engine 3 07-04-2004 01:18 AM
