Floor mounted Master cylinder - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2011, 07:19 AM
Working on a 54 Ford P/u. Looking to replace the floor mounted Master cylinder. Disc brakes in front, Drum in rear.
I know what's in the stores, but I like to do more with home-grown engineering, stock parts swapping, etc. As allways dollars and money tops my list. Do you have any suggestions
Old 12-02-2011, 09:48 AM
I've used the Ford and GM master cylinders form parts stores with some success, but the corvette copy master cylinder sold by most hot rod places ends up costing almost the same and it has the benefit of having ports on both sides of the M/C to make routing brake lines easier. JMO, but that's what I have fianlly settled on.
Not sure where to start on this one frame mounted master cyl Studedean Suspension - Brakes - Steering 4 09-19-2011 08:59 PM
Frame mounted master/booster combo--appreciate advice trifivefan Suspension - Brakes - Steering 1 09-05-2009 01:38 PM
mounting master clyinder under floor, how to locate? 427v8 Suspension - Brakes - Steering 6 02-20-2009 02:28 PM
Floor mounted emergency brake by Lokar Countilaw Suspension - Brakes - Steering 7 02-09-2008 06:51 PM
new master cylinder kimber Suspension - Brakes - Steering 3 01-24-2006 02:42 PM
