Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Floor Pans
Thread: Floor Pans
Old 01-22-2004, 10:54 AM
Thom Laybourne's Avatar
Thom Laybourne Thom Laybourne is offline
Fine cutter
OK. I have a very very fine cutting wheel. I should be able to temporally remove the upper with out any distortion. It feels like this is the original factory pan and they might have spot welded the center piece. I will keep the door closed while I remove it. Then replace allowing clearance for the new pan. Thanks.
hr41pearl
