Floor/ Rocker/ Inner Rocker Connection - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2014, 10:41 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
The floor/rockers and inner rockers on my rod have been repaired with new chunks of metal which I need to remove.
This a a 1941 Chrysler. Anyone have a cross section or pics of how the 3 pieces are supposed to connect with each other?
Or does it even matter, since it's a rod anyways?
Old 01-29-2014, 05:30 AM
deadbodyman's Avatar
Wiki Edits: 11
These Plymouth rockers may be the same,what do ya think? I have detailed mechanical drawings complete with measurements that I made when I made the rockers ...I made these full length (front to back) ..I liked the look better so you have to shorten the length if can use them or cut the bottom of the 1/4...
If I remember correctly the floor just welds to the top of the rocker (no lip).Of corse ,I did a body drop so my floors aren't original but with 16" of ground clearance theres plenty of room to drop the body too..
ID:	117177   Click image for larger version
ID:	117185   Click image for larger version
ID:	117193   Click image for larger version
The Following User Says Thank You to deadbodyman For This Useful Post:
123pugsy (01-29-2014)
Old 01-29-2014, 08:28 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Thanks Mike.
Mine has new aftermarket rockers but everything is fudged up by the previous owner.
Thanks for the pics. I need to do exactly that with my floor for exhaust clearance.
Old 01-30-2014, 04:38 AM
Wiki Edits: 11
I think I have a pic of them welded together but whats a litte different is the bottoms are not flat ,they drop down at an angle,also the inner and outer are more upper and lower since the inner rocker is under the outer..do these look like what you have on yours?
ID:	117553   Click image for larger version
ID:	117561   Click image for larger version
ID:	117569   Click image for larger version
Old 01-30-2014, 04:44 AM
Wiki Edits: 11
The first pic shows the two pieces at the left of the pic you can see the unusual shape of the inner (bottom) rocker
the third pic shows the top of the rocker (the left side is the out side) the inner (bottom) is a bit wider and they are welded together leaving a lip for the floor to weld to ....
Although its a bit hard to tell, if you look close, this is the inside of the rocker when welded together. the right of the pic is the outer ,notice how the bottom angles up...That's all I got Puggs ,I hope it helps...
Old 01-30-2014, 05:36 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Thanks Mike.
Yours is somewhat different as your door bottoms flare out.
I wish mine did. I love the look.
My inners just drop straight down. I was thinking about removing the pinch weld at the bottom somehow.
Anyways, I'll be getting her on the rotisserie within a month (I hope) and I will brace the body and cut out the floor before getting it dipped. I can figure out how to go after that.
Thanks again Mike.
Old 02-07-2014, 07:37 AM
Too Many Projects's Avatar
A few beater muscle cars
Last journal entry: continued
This is how my '67 GTO is assembled. It seems it would provide more support for the floor pan being under the outer rocker, like this, than sitting on top, depending on the welds to hold the weight.
If you are going to fabricate the pan, you can assemble it any way you want for structural integrity.
The Following User Says Thank You to Too Many Projects For This Useful Post:
123pugsy (02-07-2014)
Old 02-07-2014, 08:09 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Thanks.
That's a really great pic.
Rocker help? 1967chevelle454 Engine 3 04-03-2008 04:59 AM
Roller Rocker vs. Roller Tip Rocker Ozz1967 Engine 15 01-08-2008 04:53 AM
rocker stud to rocker clearance 85406 Engine 2 07-16-2004 09:25 PM
1.5 vs 1.6 rocker's bowtieorbust Engine 1 03-13-2004 07:53 PM
rocker? bowtieorbust Engine 1 10-06-2003 02:28 AM
