Floor Shift Dynaflow - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2007, 06:33 PM
hey all
i've got a '56 Buick and i was wondering if the column shifter could be converted into a floor mount without any major modifications? also, does anyone know of a shift kit for this tranny?
Old 07-09-2007, 12:25 AM
I may be shooting off at the mouth here but here is what i think. Any after market floor shifter should work you would need to cut a hole in your floor and hook it to the tranny. And if there is a shift kit available you might check with your local tranny repair shop they seem to be able to get parts the average joe cant. I hope i helped and that it works out for you. And if your not sure about the floor shift conversion you could always use the tech line at summit or jegs. I think the guys at jegs are more freindly though.
Old 07-09-2007, 07:10 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Jegs and summit tech most likely will not know what a Dynaflow trans is or heard of one.... never know though
THe Dynaflow shift pattern is not compatible with a modern shifter detents.
I am sure something could be modified to work, it would a bit of re-engineering of parts.
Old 07-09-2007, 07:24 PM
is a Dynaflow a cable shift? i bought this car last winter and have not had the time to disassemble it, and i am to busy with work and school to do any work til this coming winter, so sorry for all the questions.
56 Buick Dynaflow YungOlSkool Transmission - Rearend 4 09-23-2004 08:35 PM
