Floor shifter for a '55 cast iron Powerglide? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2012, 03:01 PM
Last journal entry: Couple pic's of the truck finished.
I have a 1946 Chevy 1/2 ton with a '55 235 w/cast iron Powerglide and I was looking at buying a Lokar floor mounted shifter but they say they will only work with the aluminum Powerglide. Is this because the cast iron shift pattern is (P N D L R)? Looking at a picture of the shifter it doesn't seem like it would be that difficult to make it work but since I'm new to all of this I thought I would ask you guy's your thoughts on this before I buy one.
Old 02-25-2012, 03:49 PM
rick 427's Avatar
Last journal entry: 33 WILLYS
Yea..lokar shifters mount to the trans thru a series of mounting brackets,no provisions in a cast unit to mount to...but i'm thinkin, looking at my lokar,if you couldn't toss the trans brackets, and mount the shifter to the floor, using just the top flat bracket that the shifter is attached to...just a thought....because it looks like ANY shifter you get is gonna have to be a floor,not trans,mount installation.
cast iron powerglide rhoffler Transmission - Rearend 2 12-21-2010 10:27 PM
cast iron powerglide leaks slingslingbinks Transmission - Rearend 4 03-01-2009 03:58 AM
Cast Iron Powerglide Question joshx24 Transmission - Rearend 2 02-27-2006 08:05 PM
cast iron powerglide slingslingbinks Transmission - Rearend 2 05-24-2005 06:50 PM
Cast iron powerglide slingslingbinks Transmission - Rearend 13 09-30-2004 11:18 PM
