Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > General Rodding Tech
  #1
Old 01-09-2008, 11:32 AM
powerplay13 powerplay13 is offline
Floor vs Column Shift
If you were building a late 20's to early 30's street rod sedan, would you install a floor shifter or column shifter. What are most street rod guys doing these days.
I 'm building from the frame up and want to plan ahead to ensure all my clearances work.
Your thoughts/ suggestions are appreciated.
Thank you........
Old 01-09-2008, 11:49 AM
pmeisel's Avatar
pmeisel pmeisel is offline
Glad the Jeep is on the road
 pmeisel's barnstar
re: Floor vs Column Shift
Floor shifter is simpler and more "hot rod".
Old 01-09-2008, 11:53 AM
fiftyfivegasser's Avatar
fiftyfivegasser fiftyfivegasser is offline
This one uses column shift to save floor space. Works very well and it is a hot rod.
Old 01-09-2008, 02:00 PM
Irelands child's Avatar
Irelands child Irelands child is offline
 Irelands child's barnstar
Auto tranny, either way but in a Model A and even a '32, you run out of room real quick with a column shifter due to frame width, exhaust, brakes, etc.
Manual tranny - floor shift - IMO is the only way to go.
Dave W
Old 01-09-2008, 02:12 PM
streetrodderbn's Avatar
streetrodderbn streetrodderbn is offline
Certifiable Streetrodder
consider one of the hidden shifters. I installed one made by "Fairlane" it hides under the dashboard, and still has an indicator ability so you can still pass nsra safety 23 inspection. all you have is a handle like a cowl vent under the dash!
Old 01-09-2008, 02:29 PM
cboy's Avatar
cboy cboy is offline
Always Learning - Moderator
 cboy's barnstar
Actually, if you have auto and a cable shifter you could do the same thing...just move the shift handle up under the dash to hide it. In fact, I recently saw a rat rod sedan with the shifter hanging down from the roof. I also once saw a T-bucket (cramped for room from the get go) with the shifter mounted to the drivers side door (obviously not an operable door) to provide a little more center leg room. So with a cable shifter you can do all sorts of tricks.
Back to the original point, I have the feeling that floor vs. column is something of a regional preference. In some areas of the U.S. and Canada rodders tend toward floor shifters and in some areas they really seem to like column shifter (I think mostly to get away from the sameness factor associated with floor shifters. When push comes to shove, go with what YOU like...you won't be wrong.
Old 01-09-2008, 02:31 PM
Deuce Deuce is offline
CURMUDGEON / MODERATOR
 Deuce's barnstar
Every one has their own opinion ... I suggest you look at a few cars at the next car show or cruise night and see which one you like ...
I prefer the column shifter ... if you have a automatic transmission ... This photo is of my 32 Roadster with a automatic ...
The NEXT photo shows a automatic column shifter in my 32 Ford coupe. See the simple shift lever ??
The next photo shows how LITTLE room there is ... even in a 32 ... for clutch linkage and a pedal.
The next photo show a early Chevrolet van tilt column is my 32 coupe. Notice that it is very small ... and has the P R N D L2 L1 indicator built into the shifter. It also has no key on the column. I always use these columns in the cars I build.
This photo shows how small and compact the van tilt is ...
Just look at the next car event and ask to sit in the car ... and you will see how cramped and small they are. I do not want anything in the floor of my 32's ...
Old 01-09-2008, 07:11 PM
Great comments..........
Car shows in the northeast don't begin until spring, but I will certainly check out the early interiors whenever I can.
I was torn between the 2, and the various comments are helpful...
Any other comments are appreciated.
Thank you
Old 01-09-2008, 08:25 PM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
oddroddermodderate-tor
 powerrodsmike's barnstar
Wiki Edits: 126
I always preferred a column shifter in a small car, a floor shift knob always seems to find the soft spot between my tibial tuberosity, fibula and patella.
Very uncomfortable.
Later, mikey
BE different....ACT normal.
Old 01-09-2008, 09:56 PM
speed_demon666 speed_demon666 is offline
imo i like the floor shifters, i just converted my 82 pickup to floor shift and i think it kicks ***** i put a b&m streetrod shifter in it and i've been nothing but happy. i know this is a different application but i like floor shifters in hotrods especially in some of the old school rods i've seen with chain shifters and long shift rods, even though seen as not "practical" i think that they are an excellent showcase of traditional hotrodding. i'd go floor shift all the way.
just my $0.02
Old 01-10-2008, 08:43 AM
Who makes the "hidden" shifters as recommended.
I tried a google search, but did not see anything?
Thank you.........
Old 01-10-2008, 07:06 PM
Bryan59EC's Avatar
Bryan59EC Bryan59EC is offline
Car? Truck? Who Cares
Could also consider the auto shifters in the old Dodge A100 vans.
It was actually on the dash.
Old 01-10-2008, 08:50 PM
Mrwood's Avatar
Mrwood Mrwood is offline
I had an old corvair station wagon that had the shifter on the dash. But never thought of using that idea today. Might be cool and should not be hard to make.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Floor vs Column Shift"
Steering Column Install Quarter Flash Suspension - Brakes - Steering 3 05-10-2007 11:36 AM
Header collector in way of column shift linkage Warrant Engine 4 08-29-2006 12:26 PM
need help on converting column shift too floor shift . jody chevelle Electrical 1 11-29-2005 08:29 PM
c10 - th350 to 700r4 swap column shift 70chevyc10 Transmission - Rearend 7 10-25-2004 09:35 AM
column shift into 54 chev PU DV8 Suspension - Brakes - Steering 6 04-22-2004 08:29 PM
