Floorboards completely rotted out - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2004, 09:57 PM
OK, I am working on a 1965 Plymouth Belvedere. I have both seats and the old carpet out and it turns out the entire floorboard area where you put your feet on both the driver and passenger sides has completely rusted out. The rest of the floorboard is in good shape.
I was planning on just cutting out all of the rusted metal with a cutoff wheel, and welding in new sheet metal, then installing new carpet and padding over this.
This is my first attempt at something like this. What gauge sheet metal should I use? Any tricks to forming the sheet metal? Does anyone know of a better plan? Leaving anything out? Should I fiberglass over the seams to keep moisture out? Any suggestions to make the job go easier? Thanks for any help you may offer.
Old 04-27-2004, 10:02 PM
poncho62's Avatar
Wiki Edits: 5
Don't know if you can buy replacement floor panels for your car, but that would be the way to go. If you have to use sheet metal, use a thicker guage than body metal and use rubberized undercoating to seal it up.
Old 04-27-2004, 11:32 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
what poncho said.
the fiber glass will actually give moisture a place to accumulate and then you'll be back to square one. don't ask how i know.
Old 04-28-2004, 12:45 AM
FASTCHEVY's Avatar
RatRod B4 RatRods were Cool
So will the rubber under coating. A old guy I know has a 86 Volvo, clean car, has the undercoating too but the whole driver side floorboard is rotted out, it's so bad I think the whole seat could fall out.
It's like it rusted from the inside out.
Old 04-28-2004, 06:38 AM
Wiki Edits: 49
Paddock Performance & Restoration has the parts you need.
Centerline
Old 04-29-2004, 04:54 PM
Good luck it is a big job to repl. floor pans.Are you going to butt or lar your joints?
Old 04-29-2004, 07:15 PM
I was surprised to see there was a supplier for the floor pans, but at $100 a piece, I think I will make a pattern out of cardboard, then transfer it to my sheet metal, make the floor pans myself, and weld in place. I already have my molded carpet.
Old 05-02-2004, 01:35 PM
snkbyt's Avatar
ASE Master
Last journal entry: 52 Chevy for sale
I use 18 gauge cold rolled sheet metal. It can be bent over any sized pipe or shape you need also hammered and dollied. You can also smooth out the underside with weld and grind to where it won't show on the bottom. Hard to get any original dimple bends with out a English wheel with rollers though. Then I use Por15 acid cleaner and basecoat with thier Anti-rust paint. It can be sprayed or brushed.
Old 05-02-2004, 04:52 PM
camino_man's Avatar
go like he11 machine
this is a cheap, red neck, back woods way but it worked. in my 76 el camino i too a piece of galvanized heating duct metal and used a hammer to shape in place for my floor boards. i riveted it down then fiberglassed the top and bottom around the edges. it worked well for me.
Old 05-03-2004, 11:28 AM
Weimer's Avatar
Kenneth Howard hates you...
Last journal entry: door pics smaller
The only concern that I have about using a flat sheet of metal is vibration....In a stock floor pan there are usually ribs rolled into the center for support and if you go with a flat piece is it going to be strong enough? is it going to vibrate too much(noise)?
The only reason that I am asking is because I have to replace the floors in my Jag and I though for $175 per quarter floor, that I could make my own a hell of a lot cheaper, But I don't want to run into support issues later on....
Later,
WEIMER
