Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Floorpan Fab questions
Old 01-08-2008, 02:41 PM
Slomotion34's Avatar
Slomotion34 Slomotion34 is offline
Last journal entry: Mini Tubbing a 1967 Firebird Convertible Part 1
Originally Posted by Kim57
Hi Slomotion34
Looking at your project journal I see your roll cage is welded to your frame.
I think you're going to have to keep your floor separate from the body if you want it removable. You should be able to have tabs on the body to tie the floor into it for some added support. Just a thought.
Good point... the plot thickens. I'm going to try and figure out a way to have the outer floor (between the frame and body) welded to the body and the inner sections welded to the frame. That way the body can still come off. Dang, this is getting complicated. Time to stare at it awhile.
