Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Floorplan choice
Old 08-18-2010, 04:59 PM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
I welded 1/2" sq tube in mine, it worked great,or 3/4"electrical conduit,smash the ends flat and run a 10mm drill screw through it with one at the intersection of the X,instead of welding.that worked well too...
the pics clear up a lot ,I can see why the doors drop...
One good thing about fixing this kind of stuff,you cant screw it up ,you can only make it better... while your waiting for me to get those measurements check out the hinge pins and bushings for wear, its important they are tight...
