fluid ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2008, 06:59 PM
Last journal entry: Motor build up 2
fluid ?
This should be quick and simple hopefully. I just got a torque converter and am getting ready to put everything together and need to get fluid. I have a b&m torque master 2000 and the info i got with the torque converter says use b&m trick shift fluid or other Ford F type fluid. My question is if i use the trick shift from b&m should i use it in the entire transmission as well and how much fuild should my transmission use in genral. It is a Ford C-4. Its out of a 77 ford mavrick.
Old 02-14-2008, 07:13 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Yes...use either one in the entire transmission...pour 1 qt. in the torque converter before you put it on the tranny...then install. Pour 3 qts. in the trans( if the trans is empty) and start the engine and cycle the tranny and then put in park and check fluid with the motor running....continue to add fluid untill full. I do not know what the total fill volume is.
Old 02-14-2008, 07:20 PM
alright thank you
Old 02-14-2008, 07:50 PM
poncho62's Avatar
Wiki Edits: 5
Henry is right.....the fluid whatever you use is the same....The fluid is pumped throughout the trans and converter.....they are not separate as far as the fluid is concerned.
Old 02-15-2008, 09:04 PM
does anybody know what ford F type fluid is?
Old 02-23-2008, 09:04 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
The F type fluid has different friction modifier's then
Dextron.
Take care,
Rich
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 06:15 AM
Transmission fluid problems? Croz Transmission - Rearend 7 12-22-2006 02:37 AM
toploader horrible after fluid change 65fbmustang Transmission - Rearend 4 11-21-2004 09:22 PM
how low on fluid (TH350) before it quits moving? HotRodF100 Transmission - Rearend 4 10-11-2002 07:34 PM
Dot 5 Silicone Brake Fluid?? Yes or No ?? Jim Weeks Suspension - Brakes - Steering 18 04-15-2002 07:22 AM
