fluid capacity??????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2007, 03:49 PM
ok so after many nights of research and helpful hints from other members here, i decided to replace my thm200 with a thm350. in the process i figured for ****s and giggles to pull the pan and valve body in the thm200, just to get practice. after doing so i saw the problem, on the front driverside of the transmission after removal of the valve body i saw a two inch hole where a spring was located, that spring was in about 4 different pieces causing the bind up. since i already purchased the other trans, i decided to pull the old one. once i get the new one in i plan on droping its pan draining the fluid and installing a new filter. but first i need to know how much fluid to put in the converter and how much fluid in the tranny once its all back on the car. can someone help me with this info please?????
Old 07-10-2007, 03:57 PM
Jmark's Avatar
Is the 350 a new trans or used/junkyard? New converter too? or junkyard too?
If it's all empty, I add one quart to the converter then slide it on the trans making sure it's fully engaged. Then install it and add 4 quarts and fire it up. Add 3 more and then start checking it and filling until it shows correctly on the stick.
Mark
Old 07-10-2007, 08:34 PM
My T-350 (stock 2wd truck) took right at 10 quarts from a dry start. Same sequence as Jmark said, you don't want to dump it all in at once.
M21 fluid capacity mrl Transmission - Rearend 3 01-10-2007 01:02 PM
TH400 fluid capacity?? ascen1 Transmission - Rearend 2 09-15-2004 09:09 AM
fluid capacity of a ford C6 Transmission Dubz Transmission - Rearend 4 12-13-2003 11:10 AM
T-350 fluid capacity big455 Transmission - Rearend 5 06-27-2003 10:02 AM
fluid capacity for 350 turbo mtmniles Transmission - Rearend 2 04-04-2003 05:01 PM
