fluid capacity - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2010, 08:37 AM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
fluid capacity
i have a th350 and a new torque converter. how many quarts of fluid do i put in the converter before i install it and then how many quarts to fill the transmission? its a new b&m torque master 2000 converter.
Old 11-29-2010, 10:09 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
B&M recommends one quart ATF added to the TC before installation so there's lubrication at initial start up.
Old 11-29-2010, 05:29 PM
helrazr3's Avatar
thanks, i did find the spec sheet for the converter when i was up at the garage today. it said 3 for the tranny and 6 for the converter.
Old 11-29-2010, 06:03 PM
jginnovationspedshop's Avatar
th350
Th350 I completely rebuilt mine and new converter and held 13 , bm shift kit oil , from summit racing just filter change and converter fill converter and install and put about 4ish and crank engine and leave in park and let warm up and check fluid and add slowly long as in park your ok , whenever it close to. Being full go though the gears wth front brake on then recheck fluid levels
Old 11-29-2010, 06:12 PM
helrazr3's Avatar
thanks it sounds like a plan
Old 11-30-2010, 09:59 AM
SSedan64's Avatar
Auto Trans & Converter Fluid Capacity
Automatic Transmission & Torque Converter Fluid Capacity
http://www.tciauto.com/Products/Tech...d_capacity.asp
fluid capacity??????? 4dr77impala Transmission - Rearend 2 07-10-2007 08:34 PM
TH400 fluid capacity?? ascen1 Transmission - Rearend 2 09-15-2004 09:09 AM
fluid capacity of a ford C6 Transmission Dubz Transmission - Rearend 4 12-13-2003 11:10 AM
T-350 fluid capacity big455 Transmission - Rearend 5 06-27-2003 10:02 AM
fluid capacity for 350 turbo mtmniles Transmission - Rearend 2 04-04-2003 05:01 PM
