Fluid capacity Ford c6 Auto Transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2007, 05:58 PM
Have put 11 Qts. in and have been told the old c6 's hold 13 qts. Anybody that knows out there would appreciate a reply. When I put the 11 qts. in the tranny, torgue converter, cooler lines and radiator were dry. Do I have to add more and how do I avoid overfilling. Thanks .........Bill
Old 04-12-2007, 06:11 PM
Whats the tranny in is it stock or has it had a new pan put on it
Old 04-12-2007, 06:19 PM
It is stock.
Old 04-12-2007, 06:25 PM
The tranny holds 12 qts then id try adding another one slowly checking every 1/4 a quart untill the radiator and lines get filled
Old 04-12-2007, 06:26 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
that is what the dip stick is used for..... to check the level in the trans.
Do you have a dipstick & tube ?
Do you have an after market dipstick ?
Old 04-12-2007, 06:28 PM
It is an after market dipstick and tube.
Old 04-12-2007, 06:34 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
do you need the correct height for the new tube or does the tube and dipstick function or?
Old 04-12-2007, 06:38 PM
Have not modified it and it was made to use with the ford c6.
Old 04-12-2007, 06:52 PM
I know my shop manual says approximately 13 qts. so what you told me is right. Thanks
Old 04-12-2007, 07:02 PM
you bet buddy
Old 04-12-2007, 07:33 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
As I see this , you have a dip stick and tube made for the C-6.
You have a shop manual that states around 13 qts is needed..
So , was it a test to see if the answer was available here or a double check?
Old 04-12-2007, 08:30 PM
Both, the book says one thing, but I want to verify it with people who have had experience.
Flathead Ford Transmission Adapter Old school kid Transmission - Rearend 3 01-24-2007 02:04 AM
Transmission fluid problems? Croz Transmission - Rearend 7 12-22-2006 01:37 AM
Ford C4 Transmission shift positions RAW Transmission - Rearend 6 11-29-2006 10:18 AM
Ford C6 matchup to 351W? jcharlt2 Transmission - Rearend 3 01-03-2006 08:40 AM
Which Ford Auto to use rod kent Transmission - Rearend 3 09-14-2005 09:48 PM
