fluid capacity of a ford C6 Transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2003, 04:07 PM
Muscle car fan
What is the capacity of a c6 trans, i havn't been able to find a definative answer. Was thinking it was around 25pts but not sure now
Also which fluid would you suggest for a trans seeing about 260hp and 350ft-lbs?
'74 Gran Torino Project
351W, c6 trans, 9"
Old 12-12-2003, 04:19 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
I did a quick search on Google and found this question and response.
[color=red]Question:[/color]
>what is the fluid capacity in a 67 mustang C-6. i put
>in a transpak, and a new convertor, 2 qts in the
>convertor and 7 in the trans, the dip stick shows
>full, but the trans is slipping badly started out
>only 2-3 shift, but tonight while getting on it pretty
>good, it slipped bad between both upshifts, no extra
>parts after trans upgrad, i have done a few
>transpaks, oil seems normal, no color change or bad
>smell, i am using b&m trick shift, any suggestions...
[color=red]Response:[/color]
from what I read in the book the c-6 takes 12.5 quarts and according to what you are saying, you only have 9 quarts in your tranny. I think you are just suppose to put a quart in the converter as well, from what I was told.
Old 12-12-2003, 04:52 PM
Muscle car fan
thanks a bunch.
So for a standard fluid change i wouldn't have to take the fluid out of the convertor...just looking at changing the filter, and putting a new pan gasket on, so i'd just need 11.5 quarts.
351W, c6 trans, 9"
Old 12-12-2003, 06:27 PM
adtkart@aol.com
If you just drained the pan, it would take about 4-6 quarts, if I remember right. 11.5 quarts will put it extremely high, without draining the convertor. Also make sure that you check it warm, on level ground, and with the trans in park.
Old 12-13-2003, 11:10 AM
Muscle car fan
For a full transmission flush how much would it take?? And also how would i do a full transmission flush?
351W, c6 trans, 9"
