fluid fill plug on my differential is frozen.. ideas? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2007, 07:15 PM
gto_ron's Avatar
The fluid fill plug on my differential is frozen in the housing. The 3/8" drive inside square corners are completely rounded out. I just rebuilt the differential and the interior is dry except for the assembly lube. Is there an easy way to get this thing out? This must have happened to a few other list members, what did you have to do?
thanks
Ron
Old 05-19-2007, 08:35 PM
DesertrusT's Avatar
Jailbar Revolutionary
A friend of mine, JB welded some vise grips to his plug and muscled it out with allot of uummph and leverage, I assume you are trashing the plug and have a set of vise grips that dont work quite too well anymore.
Old 05-19-2007, 10:30 PM
Take a old ratty 3/8 drive extension ... weld it to the plug.
The heat will help ... and then you also have something to put a pull bar to ...
I have used some Kroil oil also.
The best penetrating fluid I have ever used.
Stuck fill plug rounded off. chirpn69 Transmission - Rearend 2 02-28-2007 03:21 PM
Transmission fluid problems? Croz Transmission - Rearend 7 12-22-2006 01:37 AM
differential fluid mitmaks Transmission - Rearend 8 04-27-2005 06:30 PM
Pop goes' the oil fill plug ??? smokin Engine 14 11-05-2003 04:48 PM
B;owing trans fluid out the fill pipe Sandman Transmission - Rearend 5 06-05-2002 08:29 PM
