Fluid question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2004, 05:39 PM
Fluid question
I know I posted a thread in the transmission section, but I'm in a bit of a hurry.
I changed the fluid in my 87 dodge lancer today and the dealer said to use ATF + 3 like most chyslers, but after seeing the dip stick, it said use Dexron II, so which am I supposed to use.
This can go to the dump, or be moved, sorry in a real hurry with this POS, really need the help!
Thanks.
Old 07-15-2004, 08:20 PM
Nightfire's Avatar
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
BUMP
Old 07-16-2004, 10:38 AM
Tazz
trans fluid's
Unless the ATF + 3 is a direct replacement for the Dexron II you should change the fluid and install the correct fluid in the trans and hope you didn't do any damage. You might want to change the filter too. I always try to install whats it says on the dipstick if I can.
Tazz
Rat Rods Rule!
Old 07-16-2004, 06:30 PM
Well see, thats what the problem is, I dont know what is the correct fluid to use.
But I think I'm gonna stick with ATF + 3, it seems to run much better. I mean I can really tell the difference.
