fluid to two wheels only
have a 40 plymouth with a 68 chevelle chasis and drums all around. am putting a power booster in( from a 84 caprice) so i had to by a power drum master cylinder. i bled the brakes and can only get fluid to the left front and right rear. cleaned the proportioning valve
but still the same results. any help is appreciated.
Have you tried bleeding the in the proper sequence? Right rear, left rear, right front, left front. And you may have a blockage.
Try gravity bleeding, if you don`t have access to a pressure bleeder. Good luck. Troy |
Would you happen to be running the combination valve as well? If so, I think the valve is off center and blocking fluid flow to the other ports.
But would that happen with fluid at the front and the rear?
