We're winning the case!
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 05-28-2008, 05:31 AM
Stovebolter's Avatar
Stovebolter Stovebolter is offline
36 Chevy Low Cab
Flush fitting a windshield.
I read many of the articles on setting a windshield and other related subjects and was hoping someone could help me. Also subscribed to a similar thread talking about chopping a top.
I was wanting to flush fit my windshield in the 36 and saw a real nice 37 Ford at a car show here in Harrison this weekend that was done this way. I really like the rubber gasket he used. It was very small and wasnt intrusive (even smaller than a S-10 Gasket)....like 3/16 wide around the edge of the glass. He called it an inverted rubber gasket. Do you know what he's talking about. He said it is used a lot on street rods now. I've been digging through sites all week trying to find what he was talking about. Even went on the sites listed in our 'how to' section and checked all of the vendors. Do you have any idea where a guy can find these on the net?
Also....on a similar note. I'm doing away with the crank out....worried about leaks and I like the 'smooth' look. Also want to clean up the look a little and hide the urethane underneath because I know the urethane wont leave a perfect uniform edge. With that said, the new windshield will have to be oversized. I'll be making a template out of 1/4 plywood and test fitting. The same guy (with the 37) had ordered his glass with the black dots...Brian said it was called Frit. Its the black coating on the inside of a new vehicle windshield that helps hide the uglies underneath. I assume it also helps the sealant adhere better to the glass as it has a dull finish (ceramic bonded to the glass). Do you know any places on the net or lead me to any shops that can do this for me as well?
Thanks,
Dave
Old 05-28-2008, 05:58 AM
36 Chevy Low Cab
So sorry folks. I finally found a thread explaining what I was needing. Mikey explained everything and I've subscribed to that thread. It seems I was spelling frit wrong when I did a search. I was spelling it as 'fritz'. Duh! Sorry.
Dave
Old 05-18-2009, 12:21 PM
CyberGolem CyberGolem is offline
Can you post a link to this?
Thanks!
-CG
Old 05-19-2009, 03:43 PM
36 Chevy Low Cab
Thanks!
-CG
Here ya go. Here's three threads related to fitting glass, types of seals, and adding your own frit.
Dave G
http://www.hotrodders.com/forum/windshield-seal-92630.html?highlight=frit
http://www.hotrodders.com/forum/cho...?highlight=frit
http://www.hotrodders.com/forum/flu...?highlight=frit
Old 05-19-2009, 04:58 PM
Thank you.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Flush fitting a windshield."
trans cooler fittings.. 3/8 hose fitting to a AN fitting? scapegoat Transmission - Rearend 6 04-14-2008 04:12 PM
"Basics of Basics" Trial fitting parts MARTINSR Body - Exterior 4 02-23-2008 09:33 AM
Which Butyl tape to use for 67 Impala windshield impalaalex Body - Exterior 3 08-10-2007 07:24 AM
Cutting curved windshield swoodard23 Body - Exterior 16 08-05-2005 10:27 AM
flush mount windshield install n3ffn Body - Exterior 6 10-28-2003 04:49 AM
