Originally Posted by silentpoet
I didn't realize it was shielded flux core.
It's not.
Twenty gauge is a gas shielded cored wire but it is not flux core, it has a powdered metal core that is entirely different than gas shielded flux core wires (duel shield). It does not leave a slag over the weld bead and it welds much more like solid wire than duel shield wires.
BTW, those duel shield wires are fantastic stuff and would probably be as good or better than Twenty gauge if they were small enough but .035 is as small as I have found and that is just not quite small enough for body work, like .035 solid it could be made to work but .023 solid works better. My favorite is Hobart ExcellArc 71 which is available from .035 up to 3/32" in size, most of my welding is done with ExcellArc in 1/16". It will bridge a gap better than anything I have ever used and will weld overhead almost as easily as welding flat, something most other duel shield wires will not do. You guys who have a MIG welder big enough to burn .035 or even .045 might want to try some of the ExcellArc for general welding, I think you will really like it! It produce an excellent low hydrogen weld that can be used for welding alloy steels or mild steels, basically anything you would use E7018 for.
