which fly wheel? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2013, 04:53 PM
Blown 23 T's Avatar
I'd Rather Be Blown
Last journal entry: Paint remover
which fly wheel?
I am rebuilding a 67 Camaro. mostly for street... mabie a little track....it has a zz3 350 crate motor. M22 trans and a Pontiac 8.2 posi Diff with 3.73 . the clutch is fading fast. it has a GM 14088646 fly wheel (10.5) i think... with a 10.4 plate and disk. i want to upgrade to a center force 3 duel friction in 11". the center force fly wheel is 36.3 lbs the GM 10.5 is only 16 lbs.
my questions are this..... is lighter better??? will I notice a difference????...is it worth looking for a lighter fly wheel??
Old 06-30-2013, 07:15 PM
BOBCRMAN@aol.com's Avatar
In a street car light is better. Heavy flywheels store energy. Very good for big sticky tires and sticky surface, but will destroy a set of street tires on your average road surface. Great for burnouts! but with a street gear in the rear. The heavy wheel will take more time to recover the revs and a light wheel will pass you up..
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
Blown 23 T (07-01-2013)
Old 07-01-2013, 08:15 AM
theres no reason with modern clutch materials, to use an 11" clutch. Go with a quality, light weight steel flywheel and a 10.4" same as you had if possible. I personally prefer Hays, McLeod and Ram to CF. However, a LOT of my customers just go with a Luk 'Rep-Set'. Its an OEM clutch and perfectly acceptable for a 360hp street ride. Its also cheap and available at Napa.
The Following User Says Thank You to AutoGear For This Useful Post:
Old 07-01-2013, 11:55 AM
You might have a problem if you switch to a bigger flywheel. You might also have to change the bellhousing if you don't already have the big bellhousing. Your engine will rev quicker with the lite weight flywheel. They used the lite weight flywheels on Corvettes and F body cars. As far as I know they don't sell a billet lite weight flywheel.
The Following User Says Thank You to V8&4spd For This Useful Post:
Old 07-02-2013, 07:59 AM
Im a big fan of the Hays flywheels; I think they're 30pounds and a good price.
clutch, fly wheel, transmission
fly wheel matt e Transmission - Rearend 1 06-23-2007 02:08 PM
converter to far from fly wheel 81FIREBIRDESPRIT Transmission - Rearend 5 03-01-2005 11:40 AM
HELP with numbers on sb fly wheel please!!! Robbie Engine 0 05-29-2004 06:28 PM
fly wheel 78 chevy truck Engine 9 05-19-2004 11:26 PM
fly wheel akm Transmission - Rearend 3 08-27-2003 10:16 PM
