Flywheel - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2003, 05:50 PM
Post Flywheel
I have purchased an 11" centerforce clutch. My flywheel has the part number 3973457N stamped on it. Does anyone know if this flywheel is for an 11" clutch.
I've searched the internet for this part number with no luck.
Old 05-14-2003, 09:51 AM
woodz428's Avatar
Troll Hunter
Arrow
You should be able to see the machined surface on the flywheel that the disc engages, lay the new disc on it and see if it is the right size, check to see that the pressure plate fits as well.
